Forum oppgraderinger
Etter siste sikkerhetsoppgradering (som gikk rimelig "Scheiss") (versjon 4.4.0) kommer det nå en ny sikkerhetsoppdering (v. 4.4.1) . Dette for å tydeligvis fikse forrige feil..
Dette er en viktig oppgradering som dessverre må gjøres innen kort tid. Så hvis dere opplever at forumet igjen er nede så vet dere hvorfor.
Men det vil ikke skje i dag.
For nerdene av dere som har interesse for hva som er i oppdateringen som kommer kan lese videre under..
Eller gå til linken her: https://invisioncommunity.com/release-notes/
Version 4.4.1 of Invision Community is now available.
Dette inkluderer en sikkerhetsoppdatering og vi anbefaler at du oppgraderer snarest.
Here's what's new in this version:
Version 4.4.1 is a small maintenance update to fix issues reported since 4.4.0.
Also included: 4.4.0
Major New Features / Enhancements:
Post Before Registering
Animated GIFs
AdminCP Notification Center
New Email Features:
Email Statistics
Email Advertisements
Unfollow Without Logging In
SEO Improvements:
Improved pagination with page number now in path (rather than query string) and unique page titles for paginated pages.
Improved use of canonical tags.
Improved handling of empty containers and profiles to reduce soft 404s.
Improved JSON-LD markup, adding @id tags and fixing URLs for comments.
Removed page output hidden by JavaScript.
Performance Improvements:
Added Lazy Loading for images, which will speed up page rendering.
Added HTTP/2 support with prefetch/preload.
Added support for Brotli compression.
Improved default profile photos to use inline SVGs rather than generated images, which will speed up page rendering.
Improved browser caching of pages served by the guest page cache, which will reduce the number of requests reaching the server.
Improved handing of session data for guests to reduce database reads for guests.
Optimized images to reduce file size for faster page rendering.
Other minor performance improvements to reduce database queries and fix unnecessary code execution.
Commerce Store Filters allow customers to filter products by price, review, stock, or custom admin-defined filters.
Core:
Added setting to display user group formatting in more areas (see 6 New Micro Features).
Added less intrusive browser notification prompt in Notifications menu (see 6 New Micro Features).
Added ability to show sidebar blocks to only certain types of devices (see 6 New Micro Features).
Added ability for club owners to reorder the navigation tabs (see 6 New Micro Features).
Added ability for announcements to be linked to an URL or be a title only (see 6 New Micro Features), improved consistency in how announcements are shown in different areas.
Improved UI for entering time intervals in AdminCP settings (see 6 New Micro Features).
Added a new Icons & Logos section in the AdminCP which allows providing logos for use when sharing links from the community, adding the community as a home screen app on a mobile device (along with additional settings for a PWA manifest to control certain aspects the community’s behaviour when used in this way), and in Safari’s favourites menus and pinned tabs on macOS.
Added a new UI for attachments, showing a box with some information about the file, rather than a plain line (see Turbo charging loading speeds).
Commerce:
Braintree Gateway including support for PayPal (with recurring payments), Venmo, and cards. Deprecates some PayPal features.
Added ability to target bulk mails to members who have spent certain amounts.
Added sidebar widgets for best sellers, latest products, product reviews and a featured product.
New Server Requirements: PHP 7.1.0 or higher required (7.3.x now supported). MySQL 5.5.3 or higher requires (5.6.2 recommended).
Removed Features:
Removed EmojiOne-style emojis due to licensing issues.
Removed Gravatar support due to privacy concerns and performance issues.
Removed password hashes when downloading a member list from the AdminCP. This is for security, to reduce the ease of obtaining sensitive data if the AdminCP is ever compromised.
Removed the name of the content (e.g. topic) from the “Next Unread” link which could consume significant server resources on large communities.
Oppgrader nå
Hei
Akkurat fått beskjed om at versjon 4.4.2 nå er klar for oppgradering av forumet. (Les mer om denne her: https://invisioncommunity.com/release-notes/)
Men fordi denne sikkerhets oppdateringen også påvirker forum designet må dette også oppdateres i etterkant.
Oppdateringen vil skje i løpet av kommende helg!
så hvis forumet er nede så vet dere hvorfor..
Edward
Versjon 4.4.2 av forumet er nå installert og alt ser ut til å fungere..
Temaet er også oppdatert med følgende korrigeringer:
March 20, 2019:
Upgraded for IPS.Suite 4.4.2
Reverted numerous template files in an attempt to make future updates easier
The drop-down menu when viewing a Club has been neatened on mobiles
Fixed the grid layout in the Topic Thumbnail add-on
The “Manage album” drop-down menu can now wrap if necessary, preventing the layout from breaking in certain languages
Fixed the Enhanced User Profile add-on on mobiles
The alignment of the Network Status table has been fixed
Re-coded the “highlighted replies” feature to use css variables. This makes customising the highlighted posts much easier
Men jeg har ikke funnet noen nevning vedr. dette med utsendelser.. og om det var en feil i selve forumet..
Edited by Edward H. Valholm
Oppdatert tekst
Fra Tapatalk:
Hi Torstein,
Thank you for contacting Tapatalk!
The forum you are trying to reach is running on an outdated plug-in hence the issues. We’ll contact the forum owner to update their plugin. Please report the same to your forum admin as requests from members are looked into more quickly. Thank you!
Vis sitert tekst
Thanks,
Jocelyn
Sent fra min SM-G960F via Tapatalk
